Today i recieved my nice new shinny 3570k, msi gd43 z77 mobo, ocz agility 3 and a gelid cooler.
Now the problem starts, fitted everyhing together just fine
plugged in my monitor, m&kb and started it up.
All the fans from my gfx to the psu are spinning but i have no post beep and signal to the monitor, so i plugs the monitor lead in to the mobo's dvi slot and still no signal.
I've done everything i can think of but nothing works.
Rest of my spec is 8gb kingston grey, 6870, samsung f3 and a ocz 600w modxtreme.
Will phone ocuk's support line tomorrow but i thought i'd post here first incase its a simple fix and saves me a phone call.
cheers.
plugged in my monitor, m&kb and started it up.All the fans from my gfx to the psu are spinning but i have no post beep and signal to the monitor, so i plugs the monitor lead in to the mobo's dvi slot and still no signal.
cheers.
psu which has a 8 pin cpu cable so i'll try that if my ocz wont work, but wont be using it because it says the 12v rail outputs 384w and psu calculator rates my system as needing 391w, plus it only has 1 6 pin gpu cable so i'll be having to use a 6 pin extension cable which i have.
