Bit of a technical question
1 Sep 2005
im a little new to this so please bare with me :p
Iv just bought a 19" widescreen TFT which i use for my PC and my Xbox 360.
Now the problem is that the xbox 360 does not output at 1440x900 (the monitors nativ res) so some scaling is gonna take place.
im confused on which to do:
Do i use 1280x768 (which is a aspect ratio of 16:9.6 which is very close to my 16:10)
or do i use 1280x1024 which (iv read on internet somewhere) has a higher pixel density than 1280x768
:confused:
If I were you I'd just test each and see which you prefer the look of, I have a very similar setup and I find the 360 looks better at 1280x1024 but the difference is negligible, thats just my opinion though.
