I have a toshiba laptop whith vista 64 on it.
Thje product key has been rubbed off the bottom so I have extracted the license key using coolbeans software.
The install is so badly damaged I think a reinstall is the easiest way forward.
This is where the problem starts.
The recovery media doesnt work (on 4 DVDs and the process gets to where it should start formatting the disks and then just does nothing)
My OEM copy of vista SP2 will not work with the key (gives me a message that basicly says none of the versions of vista available are compatable with this product key) So I tried an OEM vista with SP1 and that doesnt even load the recovery screen.
Why does this key not work with windows ?
Is there a "tech" version of windows that will let pc repairers install windows using the product key supplied without this kind of problem as this isnt the first time I have run into this problem.
Regards
James
Regards
James
