It does but its an absolute ass to route the cables and if you shove it in it will kind of bend the back bracket a bit so mount it with a couple mm sticking out and you will be fine.
If you use braided cables you will get it in nice though as the cables wont be as thick and hard to route through the holes.
Can't believe you swapped out your prodigy already Monkeyspaz5000 xD It must have been a right pain to build a watercooled system in there, then you buy a new case haha
My Prodigy had all broken handles, the screw tabs was crushed and snapped off I finished the build and it's cooler than my Antec1200 which was 42 Idle and this is 22 Idle! I need a carry case or something now, what's a good case/bag for Prodigy?
Not a big fan of this one, but i'm sure someone out there will love it.
On the other hand, I can see this one selling like hot-cakes because it looks awesome.
still waiting for the PSU extension brackets to become available then I will put my main rig into one of these, already have one for my HTPC and love it
just get this psu instead - http://www.silverstonetek.com/product.php?pid=350
650w 80+ gold. only 140mm depth.
fits like a charm in the prodigy.
(yes i have one already)
ocuk dont stock em. but a quick google should show you which etailer does.
