Bitfenix Recon problem
18 May 2010
Hi,
I was extremely happy with this when I first fitted it, it seemed to do exactly what I wanted, it quietened my 540 Air down to near silent but after nearly a week I'm considering DSR'ing it as its started to drive me bonkers
It will do exactly what its supposed to and then it will pick one channel and start revving the fan up and down randomly almost as if its rebooting the channel, this causes a loud chirp from the fan as it spins up to 1300RPM and then drops to 0RPM and then back up to the normal under 30C speed, it will then either do it again straight away and repeat or it will wait for a few minutes or so and do it again or sometimes it does it totally randomly, this cant be doing the fans any good and its just as annoying as having all the fans run at full pelt completely defeating the purpose of the reason I bought the controller
Has anyone else had this issue?
