BitFenix shinobi and corsair A50 cooler
25 Mar 2010
have both of these that arrived today but by the look of it the cooler looks as if its going to be a little tall to fit in the case.
Anyone know if it will fit or not, if not would i be able to get a refund at all from overclockers (unused but taken out of box), and anyone recommend a cooler than would fit in the case?
Thanks
Which Shinobi do you have?
http://www.bitfenix.com/global/en/products/chassis/shinobi#support
Frequently Asked Questions
Q: What is the maximum clearance for CPU coolers on Shinobi and Shinobi Window?
Shinobi Window maximum CPU cooler height = 159.5mm
Shinobi maximum CPU cooler height = 161.5mm
http://www.corsair.com/cpu-cooling-kits/air-series-air-cooling-cpu-cooler/air-series-a50.html
Heatsink dimensions 159.5mm x 124.6mm x 81.2mm
It should fit with just a Rizzla gap left, but manufacturing tolerances do vary.
so by the looks of it, its going to be slightly too bit, well hit n miss by look of it. dont want to install it though find it doesnt fit and then not swap it for different cooler or get refund
if it doesnt fit then you can definitly get a refund from OcUK. i was in the same situation but with a different case and cooler, and 5UB said it would be fine sending the cooler back under DSR. luckily i didnt have to though
good news it fix, with quite abit of space aswell so all is good :). once i finally get it up and running is there a way i can find out cpu temp or temp of each core so can see if thermal compound has been put on well enough etc?
cheers guys. one last question, would it be ok just to put in my OS HD in for now, and then add my other sata's to system later? wont cause any probs will it?
