Bits Power Question
Is there away you can tell if they are work for rigid tubing? I find a lot of sites don't really give much description of the product
Well, yes.
The angles are g1/4 threads, so for hard tubing you add your compressions on the end of you BP stuff. If you're wanting just to use BP you're limited to using just the multi link stuff.
