Bitspower Sedna O11DXL
9 Mar 2021
Hi Guys
I am looking to get the Bitspower distro plate for the o11 dynamic XL however i cant find any stats on the pump. It says its an S1 pump but cant tell if thats DDC or D5 to see if there is a need to swap it out.
I dont think the tubing runs are gonna be that restrictive but i do want to make sure i get as good a flow as i can as it could well be running quite hot
It’s neither ddc or d5. It looks similar to ddc but not exactly the same and on the distro plate:https://www.bitspower.com/support/1537/replace-pump-bitspower-touchaqua-sedna-o11d-lite-lian-with
you can also swap out the s1 for a ddc pump though bitspower only confirm there own ddc (fair enough) with correct screw use https://www.bitspower.com/support/1...c1-for-touch-aqua-sedna-side-lian-011-dynamic
all that said, based on the paper specs on bitspower site of the S1, it’s broadly similar to something like the EK DDC 3.2 PWM elite which is more then fine for most builds.
