So I've had a weird problem for a while where after boot seemingly randomly my computer will get incredibly sluggish. I eventually found that my cpu was reporting a temp of 100C and was throttling (understandably) - this is at idle!
I open up the case to see if the liquid cooler or radiator or fans have packed in. No, cooler is humming away and not at all hot to the touch, fans are spinning and one of the braided cables running from the cooler to the cpu is warmer than the other but not hot - seems everything is normal.
Now, I open up the BIOS and as I'm on the fan speed page where its got a cpu temp reading it nose dives from 90C to 25C in about two seconds, counting down all the way through 10/20 degrees at a time. Impossibly fast heat dissipation.
When I boot the computer normally it will always go up to throttling temperature on hwinfo64 but it's physically not hot at all.
Heres the kicker, if I boot the pc, go into BIOS and save and exit without making any changes it will boot and stay at 25/30C and remain completely stable to use until its rebooted or turned off..
What is going on?!
What is going on?!
