Hi,
Im getting 52oC idle and anything up 85oC on load, sometimes 90oC on my i7 920. Asus Gene II motherboard fyi.
This is using a mini scythe ninja and im absolutely confused as to what is causing this as ive installed countless cpu coolers with Artic Silver 5 so it isnt how the cooler is mounted.
Three different temp resources are also telling me these temps too
Other temps are fine.....this is also with the mobo outside the case.
the heatsink itself feels luke warm, certainly not the type of heat off it you would expect from temps records this high.
house is also of average temp if that is of any importance.
dont notice any performance differences though.
those temps are perfectly acceptable considering the overclock........mine however.......is completely at stock.
