After recently looking at the minimum system requirements for Call of Duty: Black Ops, I was worried as my CPU is just a tiny bit below the minimum requirement.
Here are the system requirements:
CPU: Intel® Core™2 Duo E6600 or AMD Phenom™ X3 8750 or better
RAM: 2GB
VGA: Shader 3.0 or better 256MB NVIDIA® GeForce® 8600GT / ATI Radeon® X1950Pro or better
DX: DirectX 9.0c
OS: Windows® Vista / XP / 7
HDD: 12GB
Sound: DirectX 9.0c-compatible
I'm sure that the rest of the requirements would be fine as I can play Modern Warfare 2 on highest settings with no problem.
However, my CPU is an Intel Core 2 Due E6550, which is below the minimum.
Do you think that my CPU would still be good enough to play Black Ops?
If not, should I overclock my processor to 2.5GHz? (using the stock heatsink)
Thanks for reading.
RAM: 2GB
DX: DirectX 9.0c
HDD: 12GB
Thanks for reading.
