Thanks mate
Do you get any glare on the walls and ceiling?
I don't get glare but because of the thin bezel i have a border of light on the wall from the over projection so for anyone wanting to do something similar i would suggest not going for the thin bezel.
There is a little illumination on the ceiling due to the lens but nothing major.
Thanks for the pics mate. Helped a lot.
Going to order some of the aluminium composite board this week. Just ordered the AAA. Will also grab the sprayer from amazon
One thing though the tesa double sided tape. Which one should I go for? The 50mm one is around £35. Planning a 120" screen with 5cm border all the way around.
Is there also a optimum size timber I should use to support it? I.e have enough timber to leave 10cm gap all the way around at the back?
How many coats of paint you reckon is needed?
Thanks mate.
You reckon 1ltr dulux steel steel grey 2 and 2x 120ml AAA is enough to spray a sheet 160cm x 276cm a few times over?
Bought the wood yesterday. 4x 70mm x 18mm x 2400mm. Will do nicely for the frame
Parts should be arriving today!
EDIT: One more question, i have left 5cm border around the sheet, i have bought 5cm border tape from here: http://www.projector-screen-material.co.uk/products/deepblack.html
now im thinking i should have got a bigger size so i can wrap it around the edges too? do you think i will be ok with not wrapping it around the edges? i suppose work case i would do 4cm border and use 1cm to wrap
