What do you need to avoid the electricity blackouts. Some sort of battery and inverter presumably, Anything else ? Presumably I'd need an electrician to wire it in just wanted to get the kit first.
I'd mostly want to be sure the freezer was ok.
Your best bet is to go solar panel and battery combination than just a battery based system.What do you need to avoid the electricity blackouts. Some sort of battery and inverter presumably, Anything else ? Presumably I'd need an electrician to wire it in just wanted to get the kit first.
Just get a diesel generator or a Truck battery with an inverter.
It’s a Europe thing with the energy issues caused by gas supplies. France has already had to restrict energy usage and we aren’t even in the winter yet!Without pointing fingers atat the OPanyone interested in this, is this an actual thing which UK citizens are concerned about? I appreciate the 'generator, get it done' views but also wow.
UK looking good![]()
The problem with the UK is that when an organisation (in this case the National Grid) publishes its 'worse possible case' scenario, people think that it is actually going to happen. There have been many times over the past decades that we have been told that if the worse was to happen we would have blackouts but they have never happened and, I believe, are exactly what the National Grid say they are - a theoretical potential risk but highly unlikely. I doubt there are many people buying generators in the UK.Without pointing fingers atat the OPanyone interested in this, is this an actual thing which UK citizens are concerned about? I appreciate the 'generator, get it done' views but also wow.
It's been sensationalised in the Daily Mail and on Facebook due to the leaking of a Rolling Power Cut "Plan"Without pointing fingers atat the OPanyone interested in this, is this an actual thing which UK citizens are concerned about? I appreciate the 'generator, get it done' views but also wow.
Ok So ideally it would be good to be able to keep the gas central heating on and the lights. How do solar battery systems work though, does the battery power the whole house or ... something else ?Your best bet is to go solar panel and battery combination than just a battery based system.
As the additional cost of installation of the solar panels will be negligible in the long run
