- 25 Mar 2004
- Fareham
Diesel generator. Or a solar panel with a battery but that probably won't generate much leccy in the middle of winter.
You can force charge the battery though when you get power back, you could float the battery at say 50% and it would be capable of running for a bit. The issue here is that you'd also want to float the battery basically all the time with a certain minimum charge.
