blade runner wont install
The setup file is probably a 16bit executable which means you can't run it on a 64bit OS. If you have access to a 32bit windows you can install it on a VM and run it from there.
Personally I use VMWare Player since it is free to run the VM. To create the actual VM I've used EasyVMX
so i take it i just run a VM and install the 32bit version of windows 7 that i have on disk and i should be good to go?
i'd thought of installing it on an old pc i have laying about (runs windows ME) and then using my home hub to copy the game over to my main pc, would that work?
Aye should work with 32bit win7 and also possible that it could work if copied over. Depends on whether the game is exe is 16bit.
I had a similar problem with Red Alert 1 where the installer was 16bit but actual game exe ran okay.
Theres a torrent about that has a custom installer for win vista/7 comps and it works. As my original had issues so grabbed that and is fine tho sometimes have to alt and tab cos of screen but thats ok.
ahhh sweet. i'll have a search for it, is it easily enough found through google?
