or you can crack all injectors off, turn over car, as a clean supply of derv comes out each injector close it with spanner,then close the next injector that derv comes out keep turning the engine over until all injectors have a airless supply of derv, job done! works on all dervs everytime and is fool proof, is a little messy though and after you start closing the first injector it will start to fire, but just keep cranking it over. will not need towing, and works all the time.
