bling help
5 Aug 2013
I've got a corsair 540 paired with a h100i but unfortunately ocuk is out of stock of the orange Alpenföhn 120mm I was going to use. Are there some orange replacement fans available in 120 and 140mm that give as good cooling or will I need to spraypaint the colour rings of some corsairs to keep performance up?
cheers snips. I'm considering these, your thoughts please...
YOUR BASKET
1 x Xigmatek XAF-F1453 140mm LED Fan - Orange £14.99
5 x Xigmatek XAF-F1253 Orangeline LED Fans - 120mm £9.98 (£49.90)
I want the h100i fans direct off the mobo but had planned to use some SATA to PWM adapters then some fan speed reducers to get them cables out of the way and off the motherboard so they are out of sight. As these aren't pwm fans am I going to need a full blown fan controller?
