Right, went for a ride before work and here's some observations.
This is most likely a fault with the custom rom on my phone as the release notes do state that there are some issues with bluetooth and some in car bluetooth systems. If I run a sat navprogram whilst playing music, the sound keeps cutting ion and out. If I use them seperately they both work fine. What I shall do in the morrow, is try it with my Nexus 7 and see if they both work fine.
As I said a little tinny, my scala rider chepo version, non phone music compatible, isn't as tinny.
At speeds of 60mph, and a little above, it's fine. I shall test it faster tomorrow.
I haven't tested a phone call on a ride yet so I'll try that tomorrow as well.
So far so good and if it is the custom rom on my phone that's the issue with having sat nav and music at the same time, then I shall keep trying rom's till I find one that works properly.
Unless I run into some major issues, I think for the money it's pretty good.
