Hello, I have an iphone 12 pro max (ios version 26.6.2) with beats powerbeats fit. Ive been using the 2 with no problems for years. Suddenly for some reason im starting to get problems listening to podcasts. Its any podcast (of the set i listen to anyway). Beats connect ok to iphone, podcast starts ok. Within minutes I start to get what i can only describe as static sounds, then after that starts within a minute the sounds goes completely. Its like detuning a radio, its not just static and off, it gets worse over a minute or less and sound fades out to silence. Iphone still recongises its connect to buds as it shows them and also doesnt flick to internal speaker. Iphone connects and plays ok on a bluetooth speaker, so i assumed was something do with the airpods. However, playing music from itunes or whatever it is now, works fine, all the time, every time. This indicates to non technical me that iphone, bluetooth connection and beats are all working ok.Tried forgetting beats and re-pairing, and ensuring firmware updated (i followed googled instructions, i assume it worked). Anyone have any ideas what problem and solution is please?
