- 1 Sep 2005
- Scottish Highlands
do you mean focus closer so that the depth of field still brings the foreground into focus?
Effectively yes.
http://www.dofmaster.com/hyperfocal.html
Can you explain what you mean by this ?
So try to stick to F/11 or less
by less you mean f/lowest number - f/11 ?
or f11 - f22?
You can still use autofocus, just aim at the point you want to use for hyperfocal focusing, and then switch it to manual so that it doesn't refocus when you frame the shot. Also, reading 'Understanding Exposure' is a very good idea, it will help you with understanding F numbers.
The B+W 110 ND filter is great because it gives 10 stops, problem is they are extremely hard to get hold of right now and prices have rocketed due to supply/demand.
Understanding Exposure: How to Shoot Great Photographs with a Film or Digital Camera by Bryan Peterson (Paperback - 1 Aug 2004)
They are bloody expensive!!!!
Cheapest i can find it is £80 for the B+W 77mm ND-110 (3.0) SH Filter
Is that the one i should be looking at getting as there are a few ND-110's....
Should i get the B+W 77mm ND-110 (3.0) SH Filter ????
That's the one you want if you want silky smooth water. Its a 10 stop ND so will require pretty long exposure times. Really nice filter though. All my filters are now B&W as they top quality. If long exposures is something you are into, then the B+W 77mm ND-110 is well worth the money.![]()
