Bit odd this (I think it's odd anyway, might be perfectly normal!)
Red headlight warning came on the dash. Drivers side headlight doesn't work in position 1. Does work in position 2. All the other lights work (though in position 1, car is cleverly using the indicator as a light...)
Looking at the headlights, there's only two bulbs, the lowbeam and the fullbeam. So the lowbeam bulb that doesn't work on position 1, works on position 2.
I've ordered some new bulbs, is this likely to fix the problem or is it likely there's more to it? (in which case I'll take is somewhere rather than fiddling about myself)
