I have gotten a loan of my brothers 600w OCZ power supply as mine died recently. I am trying to power a GTX 580 from it but have a shortage of connectors.
The card needs two 8 pin pci e connectors but the power supply has only one 6 pin. I do have one 6 to 8 pin adaptor.
Will I get away with using a 2x molex to 6pin pci e adaptor and then using another 6 to 8 pin adaptor to plug into the card? The supply has two lines of molex connectors, I assume I would connect one plug to each to use both power rails?
Will this setup work ok? At least til I get a replacement supply back with all the plugs?
