Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
7D durability, its quite insane !
If Nikon release a 1200-1500 pound FF D600 then canon will be forced to answer with something like FF 7D at the same price point. The 5Dmkiii is over priced so that should also come down a little.
I carry all of it to the bride's house, its in my Thinktank case.
At the church I swap to my bag, the 16-35 and 135L in the bag, 35/85 on camera.
At the venue I leave the case in the car, try to park in a parking spot as close to the venue as I can and depending on the venue, i swap lenses/gear (add flashes) as I go along.
I don't really want to argue but thought I would point out somethings after rechecking some websites to get my facts straight.The reviews I've seen have shown them to be around the same, which makes sense as all the lenses are renowned for being very sharp. As I already pointed out though the random price variation is just odd (why is the 35 f1/8 £150 while the 28 f/1.8 is over £600?).
Oh I agree, however for me the majority of lenses I have looked at have been more expensive on the Nikon system, except the ones ones Nikon don't have.
Canon do seem to have significantly more "prosumer" lenses, an area Nikon didn't seem to want to compete in, with either the basic lenses or the Professional series, very little in between.
Due to be... but I'm buying now (and Canon have had their 300 f/4 IS out for almost 15 years).
The 70-300 VR is as good as the 70-300 f/4-5.6. The 70-300L is the next step up, although like most of the +100mm area they have significantly more choice than Nikon.
For example:
Canon EF 70-200mm f4L USM £500
Canon EF 70-200mm f4L IS USM £900
Canon EF 70-200mm f2.8L USM £980
Canon EF 70-200mm f2.8L IS USM II £1800
Canon EF 70-300mm f4-5.6 IS USM £350
Canon EF 70-300mm f4.5-5.6 DO IS USM £1000
Canon EF 75-300mm f4-5.6 III (non USM) £200
Canon EF 75-300mm f4-5.6 USM III £200
Canon EF 70-300mm f4-5.6L IS USM £1150
Nikon have
Nikon AF-S 70-200mm f/2.8G ED VR II £1600
Nikon AF-S VR 70-200mm f/2.8G IF-ED £1700
Nikon AF-S 70-300mm VR £400
There are obviously gaps in both systems (like Canon not having a 200-400 and Nikon not having an 800 or the mythical 1200) but overall Canon are normally seen as the better option for longer lens choice.
As for the 80-200 f/2.8. I know they were the precursor to the 70-200 f/2.8 they have now, however I can't find it on Nikons site (sure I saw it the other day...) and none of the big stores I just looked at actually sell it. It is also not going to match the £500 of the 70-200 f/4.
I'd disagree a bit with that, although it's not as well built as the Nikon it is leagues ahead of the third party options in this sector. The point was however that I'm just grumpy because Nikon don't make the lenses I currently rely on with Canon, making any jump significantly harder to justify...
(Yes I am taking your advice from the other thread, but will probably end up with the 70-300 f/4.5-5-6 rather than a used 70-200 f/2.8 because the latter is just too big to justify for travelling, whereas the 70-200 f/4 is perfect with a TC.)
I think Nikon can get away with it. If they have a UBER high MP count camera like the D800 and then a lower MP count camera which is rumoured to be in the D600 then I don't see much of a problem. People who want high MP will buy D800 and others will save some cash and get the D600.
Where do Canon go though to separate the range and not cannibalise sales of 1 of their flagship cameras.
On topic though, i think the dynamic range and colour depth of Nikon/Sony sensors is really nice. They're a lot more forgiving in post from my experience and Dodging/Burning yields better results. Coming back to Canon on a 5Dii from a A77 I realise i was quite spoiled with DR/CD...but not with ISO...
All this Canon bashing...it's just a tool for the job
5D3 - Amazing
35L - Amazing
85L - Amazing
All I need.
I pretty much ignore everything else these days, I am lucky that i am in a position to fund my kit from my work so I am not really concerned about what replaces the 60D, it is of no consequence to me. What I have been waiting for in the form of the 5D3 has materialised so that's that. Lenses wise I am pretty much covered there as well. They do a good job and even if the Nikon 24-70 is better, so what? I am primarily a prime shooter and already got a sharp copy of a 24-70 so even the Canon's mk2 effort doesn't mean much to me either, nor do the 70-200 variants.
I am past caring about what the other side of the fence are getting up to, more concentrating on what I can do with what I am given. And on that front, it aren't too bad![]()
the Nikon 50mm f/1.8 AF-S G is much sharper than the canon, has much less vignetting (1.5 stops vs 3 ! stops wide open) and has far, far nicer Bokeh, it is also much better made. Similarly, The Nikon 85mm f/1.8G is much sharper than the Canon, and has better Bokeh.
The 28mm f/1.8 is a Full frame lens of very high quality that has only just been released = higher prices. The 35mm f/1.8 is a DX/APS-C consumer lens. Compared to the canon 28mm f/1.8, there is just no comparison at all with the image quality, the Canon version is pitiful, so bad it should be removed from the lineup, unless Canon intend for it to be used as a paper weight. On FF, the extreme corners of the Nikon is sharper than the very center of the Canon!
What makes a better comparison is the new Canon 24mm and 28mm f/2.8 IS lenses, at least they compete together optically. They are much the same prices, the Canon are a little more but come with IS. However, the Canon lenses are 1 & 1/3rd stop slower than the Nikon. The Nikon 28mm f/1.8 is an absolute bargain compared to these new Canon primes.
So you see, you have to be careful with these comparisons, Nikon is clearly ahead here.
Quite a lot to answer here so here a few random points, in no real order.
Look at reviews of the Nikon 70-300VR and the Canon 70-300L, the Nikon is basically the same lens but far far cheaper, there is very little IQ difference.
Canon do have a huge lineup of lenses and tend to update them more rapidly, no one really disagrees with that. What people don't realize is the total lineup of Nikon lenses is actually larger than canon, this is primarily because Nikon has kept the same mount for well over 50 years allowing older designs to still function. Nikon still manufactures as news and sells as new many older lenses. As I said, you can still buy a brand new 80-200 f/2.8 AF-D, you can also buy a manual focus 50mm f/1.2, even the older 50mm AF-D lens you can buy new. Your typical high street shop and small online store wont stock such lenses, bigger more specialist websites do. i can buy such lenses quite easily. I purchased my 80-00mm f/2.8 new about 4 years ago. I don't know what you mean about it not matching the Canon 70-200 f/4.0, the Nikon 80-200 cost me about 550 quid and is every bit as sharp as the newer 70-200 VR version. Actually, I upgraded the 80-200 to the 70-200VRI, but the 70-200 is not as sharp a 200mm as the 80-200 and I am really annoyed I swapped these lenses over. It is of course a little heavier.
There is next to no difference in the long lens line up between the 2 companies. No one will choose a Canon setup because they want the Canon 400mm or 600mm etc. The lenses are basically identical and matched at all focus lengths. Yes Canon have an 800mm f/5.6, Nikon used to have such a lens but stopped production because there was so little demand It was only in 2005 when Nikon stopped production. But hang on, Nikon will be releasing a new 800mm f/5.6 in the next months,
http://nikonrumors.com/2012/07/05/nikon-to-announce-a-new-af-s-800mm-f5-6-vr-lens.aspx/
What is starting to make people choose a nikon setup over a Canon is the high Canon prices of their long lenses:
Canon 600mm f/4 £10999.00
Nikon AF-S 600mm f/4G ED VR £6949.0
Canon 500mm f4L IS II USM £8449.00
Nikon AF-S 500mm f/4G ED VR £5864.99
Canon EF 400mm f2.8L IS II USM £8795.00
Nikon AF-S 400mm f/2.8G ED VR £6629.00
Canon EF 300mm f2.8L IS II USM £5399.00
Nikon AF-S 300mm f/2.8 G ED VR II £3999.95
Canon EF 200mm f2.0 L IS USM £4799.00
Nikon AF-S 200mm f/2G ED VR II £4299.00
Heck, buy 1 or 2 Nikon long lenses and you get a Nikon D4 "for free" relative to investing in Canon.
The Nikon 500mm f/4 VR is the lens I will buy in the next years, that is the best part of an extra 3 grand, the cost of of a D800 and a nice 28mm prime.
5-7 years ago and things were very different. Many of Nikon's lenses were getting old and they didn't have AF primes like the 35mm f/1.4, their sensor were also struggling to keep up with Canon. Now things have really changed. The lens lineup is almost entirely revamped at most of the critical places, a couple missing pro lenses which will definitely be released in the next years or so (800mm f/5.6 as an example), 80-400 replacement has had endless patents, expected at photokina.
There is a need for some intermediate prosumer lenses, notably a 70-200 f/4.0 to have as a checkbox lens. Some more DX wide primes, but even here Nikon is ahead of Canon in serving crop camera users (where is the Canon 35mm EF-S, Canon users have a lack luster f/2.0 version, a very good but very expensive f/1.4 or have to buy a Sigma, the sigma is much worse than the Nikon optically). The crop lens line up on both systems needs a lot of new additions, 16mm prime, something like a 16-80mm f/4 (there is a rumor Nikon will release such a lens this year).
What Nikon doesn't need is a load of VR and Non-VR versions of lenses, extortionately prices DO lenses, etc. I see no need for Canon's choices here.
Nikon also need to update their PC/TS lenses and get a 17mm f/4 TS like the canon (again, there are patents and strong rumors)
