- 27 Jan 2005
- S. Yorks
Interesting, what convinced you to go with a pressurised system? Of the four companies I sourced for a quote no one mentioned the pressurised system but I guess the house isn't big enough for such a system. Three of the four blokes said a combi boiler would be best, the fourth was non-committal and would fit whatever I decided, which is fair enough.
For us, we knew existing tank solution doesn't work, the combi boiler looked like it was perfect, but having two daughters who are starting to fight to use the showers at the same time and also speaking to the other households on our estate that we knew had new boilers fitted there was only one with a combi boiler that said it worked for them (however they only had one child and never ran multiple baths / showers / appliances at the same time). Also after speaking to 5 different plumbers/tradesmen, three said pressurised systems one said combi and the other said conventional tank - we went with the majority vote.
Will see whether its the right decision in a couple of weeks once it's fitted and will report back.
Matt
