Yes defo a problem oh well
It will only work when i hold the reset button down.
what do u mean by external controls?
when it says max youve put the boiler into service mode.
the fact it will fire up and give heat shows the problem is your external control is it giving hot water?
timer/room stat
condenser pipe underneath the boiler you can literally pull off and empty any water build up in the boiler. Then insulate the pipe stop it freezingi went outside and it looks ok? I mean how do i know if its even frozen lol
dark out there man
File this under clutching at straws already clutched, but I had a similar puzzling issue with a nearly new boiler after I accidentally caught the receiver for the thermostat, next to the boiler in the garage. The cover was nearly perfectly in position and didn't looked to have moved, but had contacts on the lid, which was slightly loose. Pressed it firmly home, problem went away.
Good luck getting a solution before festive triple time kicks in.![]()
Which WB boiler do you have?
Yeah we've had customers with rodents eating through cables and pipes before now.
Did your 'plumber' check the switch live from each motorised valve? It's way more common to have a faulty microswitch in the valve head than a rodent problem, unless there is evidence to support the presence of vermin.
I did say there was nothing wrong with your boiler and if its a nest id rip it out and fit something else seen far too many receivers go faulty and less than 12 months old
Without telling someone their job, he needs to check each orange wire in turn and then the switch live at the boiler, to determine where the break in the chain is.
