Breamy said:wel i bought an antenna which says it can be used for digital but i get absolutely no signal in my room for either digital or analogue so i plugged it into the main ariel socket and i get around 3 channels and the signal is really bad and keeps cutting out
Breamy said:ive tried everything with the antenna its useless.
Tru said:Get a wideband aerial, they cost about £15-20 from a decent supplier and will give you a wall-to-wall reception, mount it nice and high and you'll get 40+ channels.
Kell_ee001 said:My problem is that I'm in a house share so I don't think a wideband aerial is suitable![]()
Tru said:Aye they're pretty big, but if there's already an aerial on the roof or in the loft it could be swapped for the wideband.
Or you could decorate it with sparkly things and hang it from your ceiling.![]()
Kell_ee001 said:LOL
While I appreciate the thought sparkly doesn't really work for me and unfortunatley I doubt my landlord would be willing to change the aerial (and I don't intend to buy one for him to keep either!)
I've put off buying an amp though because I've heard so manyt times tha they just aren't worth it - anyone have an personal recommendation?
