Boosting .Mov sound.
Yes you can...
When the clip is in the timeline....
Click once to highlight the video clip, then click the audio icon in the middle of the window....
You will be presented with this window, where you can adjust the volume...
Export the video and you're done!
Yeah sorry, that was among the first things I'd done!
Normalizing it helps, but only a little.
Can't get the project to transfer into FCExp either :(
Well if you normalise it it usually brings louder clips down, as opposed to quieter clips up. Just try boosting the volume, see if that helps. Obviously past a certain point it'll distort but see what you can do with it.
On the subject of AV....
Why/how does the audio go out of sync with the picture in some flv/mp4s?
I've seen this in downloaded YTube files, e.g. a docu split into several files
No go in iMovie(that I can see) other than normalising. Very limited app afaic.
Looking into FCE.
Normalising will boost levels to the maximum until they threshold on clipping - which you don't want the sound to do.
If you normalise then that's about as far as you're going to boost the sound before you wreck it.
iMovie allows you to separate the audio and video in to two separate channels, then just delete the video channel.
http://support.apple.com/kb/TA25603?viewlocale=en_US
You may be able to resolve audio synchronization issues by extracting the audio from the video clips in the iMovie project to a separate audio track:
1. Select all video clips in the timeline (from the Edit menu, choose Select All).
2. Extract audio to a separate track (from the Advanced menu, choose Extract Audio).
It is likely something to do with the various frame rates for video, 24fps, 25fps and 23.9.
The audio is not linked to each frame of the movie, and so when a movie is played at 23.9 but recorded at 24 (or 25) then there will be drift. That is the most obvious case. Rounding errors, noisy clock sources et cetera can also lead to increasing async.
"The 24p frame rate is also a noninterlaced format, and is now widely adopted by those planning on transferring a video signal to film. But film- and video-makers turn to 24p for the "cine"-look even if their productions are not going to be transferred to film, simply because of the "look" of the frame rate. When transferred to NTSC television, the rate is effectively slowed to 23.976 fps, and when transferred to PAL or SECAM it is sped up to 25 fps. 35 mm movie cameras use a standard exposure rate of 24 frames per second, though many cameras offer rates of 23.976 fps for NTSC television and 25 fps for PAL/SECAM. The 24 fps rate became the de facto standard for sound motion pictures in the mid-1920s.[1]"
Do you mean for playback purposes?
I use VLC to crank the sound on a particularly poor quality video.
