Boot Problem & Crashing
Permabanned
15 Aug 2006
Gainsborough, Lincs, UK
Ok this happened a few times and it seems to do it more frequently....
My system is hitching studdering through the speakers then rebooting, then it wont always come back into windows will freeze on black screen just after the windows loading progress bar.
Driving me mad, its just random somtimes it'll do it sometimes it'll boot normally! Not as if its a pattern or does it when i do a certain thing. Just sometimes will and sometimes wont!
Any help would be brilliant!
Gigabyte K8N mobo (939)
Athlon x2 4800 (:-P)
kingston 3200 2gb (2x1gb) (not the ram, it does it no matter what ram!)
XFX Geforce 7900GT 256MB Extreme edition
500w psu (thouht was this, does it with 3 other psu's i hav spare)
not a cooling problem, i hav a antec900 :-P
Matthew.
seeing as you have mentioned the speakers have you tried a new sound card driver or disabling the sound card to see if that makes a change.
The best thing to do with random crashes is to check for updates (windows and drivers) and then to a mem test
