- 4 Nov 2011
- N.I
Boot problem with new Oc system--updated
Hi,
Recently bought this complete system with a gtx580
http://www.overclockers.co.uk/showproduct.php?prodid=FS-212-OE
Had some inital minor probs which were easily fixed with help from this forum, but have a new issue. When i first got the system, on power up it would start up, run for a cpl of seconds then power down and then power up again and then go on to boot normally. After i applied the Oc profile to the system i noticed it would boot normally everytime with none of the on, off on etc. Since then the system has ran like a dream, ran stability tests and no issues and system reports back as 4800 under load on cpu-z which confirms the overclock. The system has been 100% stable.
So today it has started to do the on, off, on thing totally randomly on start up again, this results in the system locking up on the loading windows 7 screen with the 4 glowing colours. Once locked up, it will sit like that forever unless i intervene. Liek i say, this is random. Sometimes it will boot normally, other times it will on, off, on then lock up.
Beyond applying the oc profile to the system in bios, it is all stock settings pretty much, so anyone got any ideas what may be causing this? Have removed all usb devices on start up and still randomly boots or decides not to.
Cheers in advance
Hi,
Cheers in advance
