I bought a new HDD recently and decided that i'd install Windows on the new one and use my old one as a storage drive. Easy process i thought, install Windows on a partition on the new drive and format the old drive.
Initially, i had the option of choosing which Windows installation i wanted to boot to, so i had a dual boot scenario. So i format the first drive thinking that it would automatically detect the OS on the new drive and boot into that, but it's not. I've had to reinstall windows on the old drive just to be able to boot up.
Disk management shows that my old drive is my system drive. All the data on my new drive is intact on a separate partition. Whilst fiddling around, i stupidly marked the partition as active on my new drive. Now Windows won't boot as it can't find the correct boot files to be able to start windows. I've unplugged the new drive so i can boot into Windows on the old drive.
Is it a case of copying the right boot files onto the new drive using the recovery console? How do i change the boot priority so that my new drive is my system drive? Any help appreciated.
TIA
TIA
