Booting from a cd when using RAID??
26 Apr 2008
York
May sound a bit noobish but i cant for the life of me figure out how to boot from a cd. If i set the cd drive as priority in the bios it changes nothing. Just goes through the usual raid check. Want to check the hdds and to do that need to boot the program of a cd! Any help?
If you set the boot priority to cdrom then it should boot from the disk unless the disk isnt bootable, Try it in another pc and see if it boots. You may also struggle checking the disks if they are in a raid array. If its just the phsical disk you want to check you may have to set the disk type to IDE rather than Raid.
i agree it should!! it doesnt even work with windows dvd. So your saying to check the hdds i should take them out of RAID? Would prob be able to boot from cd then too.
