booting into 'normal' mode after safe mode problem....
13 Sep 2003
Doncaster
Chose safe mode on a laptop I'm sorting (Windows 10), but want to get back to booting in normal mode. Only thing is she cannot remember her password, which as far as I can tell, is needed to do just that by every method I've read of (she normally uses her pin number, which she does know). Is there a way around the password issue?
thanks.
If it's a Microsoft account, go through the usual recover password stuff on outlook.com
If it's a local account, then use the sethc truck to get a command prompt up and reset the password that way.
Found out since there was nothing worth keeping so just wiped/reset it. @UnworthyBean There was no option to enter the pin number instead (read on MS site you have to use password when attempting safe mode). @ PiKe Was actually a local account but I'll make a note of the seth trick. I had tried to get a command prompt through the recovery options (there's a command line to delete the safe mode switch) but it still wanted the user pass first (grrrr)
thanks fellas.
thanks fellas.
You have to boot of the install media or into a Windows PE like Macrium.
