Booting issue
13 Jun 2007
Dorset
Windows 11
NVIDIA GeForce RTX 3080
ASUS Pro WS X299 SAGE II (LGA 2066 R4)
BIOS Up to Date
Every time I reboot my PC it posts but Windows does not load.
(Actually, that's not true. I think Windows is loading but the monitor and keyboard close down)
My workaround is to shut down and reboot.
Generally on the 2nd attempt windows loads.
MB states Code AA
I feel it is a GPU issue, but I cannot say for sure.
Has anyone else had this problem?
Had this same issue and BIOS battery was replaced - problem solved.
When you say the Bios Battery, do you mean the CMOS Motherboard Battery as indicated on the MB diagram?
Check that your gpu is the 1st choice for video output in the bios.
I cannot see an option to specify the GPU in my BIOS.
I only seem to have these choices unless I'm in the wrong advanced section.
I can't see anything in the manual I dld from Asus :/
But let's start at the beginning with the simple stuff.
#workbrainactivate
What storage do you have?
What psu are you rocking?
Have you tried using the primary video out port on your gpu? You might need to try each one.
Does your cpu have an igpu? Remove your gpu and try that.
Try a different vid cable.
Reset the bios to defaults and see if that changes anything.
#workbrainactivate
Operating System Windows 11 Pro for Workstations 64-bit
CPU Intel Core i9 10980XE
RAM 128GB DDR4 @ 1064MHz (15-15-15-36)
Motherboard ASUS Pro WS X299 SAGE II (LGA 2066 R4)
NVIDIA GeForce RTX 3080 (Gigabyte)
Storage "Samsung SSD 850 EVO 500GB" "Samsung SSD 850 EVO 1TB" "Samsung SSD 970 PRO 1TB" "Samsung SSD 980 PRO 1TB"
PSU Corsair AXi Series AX1600i
What storage do you have? See above
What psu are you rocking? See above
Have you tried using the primary video out port on your gpu? You might need to try each one. Done
Does your cpu have an igpu? Remove your gpu and try that. No
Try a different vid cable. Done
Reset the bios to defaults and see if that changes anything. Done
Ta, nice one.
Pull / disable all storage in the bios apart from the boot drive.
See what happens
you may need to disable CSM in the bios, with a older board and a modern gpu with a uefi bios there is a potential conflict between the 2, there is a problem with disabling CSM and it has to do with your drive the OS is installed to, if your partition is formated to MBR then you wont be able to boot if CSM is disabled, you will have to convert/re-install windows making sure the drive is setup as GPT, then you can disable CSM.
its all to do with rebar support on 30 series and up when used in older boards with CSM enabled and windows 11.
you can try disabling it and see what happens but if your pc goes to bios instead of booting your drive is setup as MBR, try to convert to GPT or re-install then disable CSM in the bios.
Thanks for the suggestion. The CSM is already disabled. So no joy.
