Bootmgr missing on m4 SSD
18 Apr 2010
Respawning...
Just recieved a second hand M4 but when i try to install windows on it, it does not appear in the drive selection bit on the windows install. But appears in the bios. What should I do to fix this? Will the command things fix it, I saw a guide i could use.
EDIT: When i let it run it will get to bootmgr missing press ctrl alt delete to restart and continue in that loop. It is there in the bios, i removed all of the other drives but should i remove everything from the SATA ports and just leave the m4 in and try that? Also my current OS drive keeps freezing on boot just at the desktop everytime. Does that mean my OS is copprupted?
Any help appreciated. Sorry for panicked post, i want my pc working again soon.
Download Parted Magic and run gparted from that live CD. It may have some weird partition on there that Windows doesn't like (it can happen)
Remove all current partitions with gparted and create a fresh NTFS partition
Managed to load windows onto it somehow but not without a lot of trouble. Everytime I try to install the xonar DG software it locks up the com puter and then freezes on boot everytime. I have loaded windows onto 2 different drives and it does this everytime. Any ideas?
