I've read the FAQ regarding adding boarders to your photos using Paintshop / Photoshop but is there any automated way to do this using a script or a seperate piece of software, so the operation is a bit more "one click" ?
Similar to Macro's in spreadsheet software you can record an action to your photos in photoshop cs, you basically just record what you are doing and then when you're done, click to do the action and it does it progressively.
you click the actions tab over on the right and then you hit the record button, do what you want, then hit the stop, then each time you want to use it you just press play.
