- 6 Sep 2016
British gas Bosch boiler, combi.
Hot water gears fine.
Thermostat does not start the boiler, if I manually increase desired temp to say 30 degrees the gas flame icon appears which should set the boiler to radiator on. But boiler does not kick in
How do you do a RF reset / relock onto the thermostat? Batteries are new enough.
