Hey i just bought a WD 500gb hdrive and a i5 at 4.4ghz
Ill start the story of what happened and then hopefully you can help me fix it.
1 - My hdrive got delivered before my Motherboard so i thought id try get 1 step ahead and install w7 on my new hdrive, at the time i knew nothing about PCs i just thought it would help me. Then i get told i done it wrong and i wasnt supposed too.
2 - Plugged all new motherboard in, hdrive, dvd drive, everything you can think of i perfected it in made sure it wasnt touching case and all cables were in the slots they needed
3 - Went into MSi bios and set DVD to first boot to hopefully boot the DVD to re write my copy of windows currently on my HDrive, no such luck i just get a black screen with a flashing underscore.
4 - I made a USB stick a bootable windows 7 thing basically so it was on usb not disc, set it to first priority no such luck.
So i just turn PC on, get my screen with gtx 260 at top right, get a blac screen with 99 in top left and A3 in bottom right, then i get the MSi logo then the black screen apears with the flashing underscore which is almost making me take a hammer to my pc
Please help me i pray to the skys someone on here knows what to do.
