Morning all
I'll keep this brief. Is it advised to replace brake calipers in pairs? Or will just replacing the "offending" one be fine?
What sort of lubrication should I use on the caliper sliding pins? Half of the internet says copper grease is no-no, the other half says it's fine
Cheers
Cheers
