Spray pentrating fluid down between the stub axle and the bearing and keep working round it with a hammer don't just hit it in one piece.
Although tbh its needs a more constant force than shock loading to get it off really, can try getting it off with your hands either of the disc with a slight wobble to see if it'll start to come off. Otherwise a puller is probably going be neeed.
Usually happens when the bearings been running a bit hot, a smear of grease on the stub axle won't hurt when you reassemble.
