Brake discs worn or pitted
27 Mar 2016
Bristolian living in Swindon
Hi all
My car Passed the MOT but an advisory was about Worn or Pitted Brake discs on the front, as it was an Advisory I'm guessing it doesn't need doing ASAP... As I'm braking from a Motorway speed I can feel it vibrating on the steering wheel. Would I be OK for the next month or two before buying and fitting a new set?
Thank you
If it’s vibrating on the steering wheel when braking then the discs are warped.
They must only be slightly warped or the tester would have picked up on it and failed it.
Yeah they said it will need replacing by the next MOT, so it should be OK I'm guessing then bud?
Yeah, I see the same cars I advised discs on last year and they’ve not been replaced and pass again this year.
Brake discs have to horrendously worn to fail an MOT.
Waiting for the weather to get a bit better before you do it huh?
Can't say I'm blame you I'm doing the same for the rears on my Volvo.
should be fine for a while but one thing to note is that i would have thought ABS performance and or stopping distance / ability to emergency stop may be compromised
i did my from discs / calipers / pads and rear drum shoes last year and i was amazed in the performance upgrade.
i think they slowly degrade and you dont notice because they fade little by little.
