Brake discs...
27 Nov 2002
How much of a lip around the edge of a brake disc is deemed acceptable? I only ask, as my discs have perhaps a mm (maybe 2 at a push) of lip around the edge. The surface of the disc is fine, and the brakes pull up strongly.
My fronts have a slight lip around the inside edge where the (non standard) pads don't meet them. They should probably be changed soon but, as you say, they work fine so... shrug. I think Oblivious' discs were the same.
I remember the guy who was looking to buy my old car felt round the brake disc, noted there was a slight lip - only just discernable by running your finger from the disc off the edge, of perhaps half a mm or so... He said - worn brake discs there, knock some money off for that...
I said, no, don't be silly, they're fine for ages yet. But the discs on my car are a little bit more worn than that, so....
It's a Pug 106gti with 247mm vented discs, 20.5mm wide.
It should tell you somewhere on the disk a minimum thickness......if its old you probably cant see it but it should say in the handbook.
