Afternoon all,
I'm after some high performance brake pads, i'm not bothered if they take a little heat to get up to decent performance but obviously don't want them to be a liability if someone pulls out on me from cold.
I am changing the calipers to the ones found on the e46 330i, which gives me 325mm instead of the stock 300mm discs, as I find the stock brakes woefully inadequate after a few hard stops. This is a very cheap mod to do if i am already changing pads and discs (£100 for a pair of remanufactured calipers) so every little helps
I am thinking of going with plain vented brembo discs, and EBC Bluestuff pads as they seem the ideal compromise between cold performance and warm performance, but I can't find them in the right fitment :\ There doesn't seem to be much choice at all for the e46 330i?
I don't really want to spend too much over £100 or so on the pads.
Also, what fluid should I go with?
Thanks,
Tom.
Thanks,
Tom.
