I bought a new Seagate 4tb from OCUK in April last year, the rest of the drives in my PC are much much older, yet it seems this newest one has failed.
Earlier I was playing a game and it kept locking up. I tried to reboot then Windows wouldn't start, I had the spinning dots.
I unplugged each HDD one by one and when this 4TB drive was unplugged Windows would boot fine.
I plugged the 4TB drive into an enclosure and it doesn't show up in Explorer, in disk management it shows just as "Read only -16384.00GB Healthy GPT Protective Partition". With no options to do anything with it.
In fear I downloaded whatever recovery software I could find. EaseUS Data Recovery is scanning and showing lots of my files, so they're on it. But of course it costs me money to restore them and I don't have a big enough drive to put them on.
I know the drive is in warranty, do I go through OCUK for this?
Ideally I need a replacement first, so I can (if I can find affordable software) get the files off then send the drive back.
Seagate's warranty process wants the drive sent first, which isn't ideal.
Or do I go through OCUK?
I've never had a drive fail in over 20 years and it being this new one really worries me. Also the fact software can see the files, yet I can't access them normally baffles me. Is there anything I can do to try get the drive seen properly by Windows again?
I have some of the files backed up but a lot aren't so i'm keen to come to a solution
Recommendations please...
