Brick wall - FX 8320 Overclocking
7 Feb 2011
I'm a bit confused!
Just set up a new FX8320 system. H80 cooler, push/pull. Idle socket temps are around 27C ("Package", i.e. Core temps are wierd at idle, from around 10C to 20C - but I hear the sensors don't work well at idle).
2 x 4Gb 1867 RAM, using stock profile in the BIOS (which matches the timings exactly).
Ran P95 overnight, no issues at all. Socket temps maxed at 55C, Core temps were much lower (sorry, can't remember).
So I'm happy that everything is set up correctly and that my RAM is working fine with no errors.
I've been trying to overclock using the multi all morning, with strange results.
I've found the limit at stock voltage is 4.2Ghz (Load Core Temp 40C, Socket 60C). But when I try to raise the voltage by one single increment (around 0.005V), the system simply won't boot. If I put it back to Auto, its fine.
However, if I reset the BIOS back to stock, I can raise the voltage just fine and Prime has no issue. The temps don't rise much either. I ran it at 1.425v to test it (seeing as that is the PStage VCore for the turbo setting, I figured it was as good a place as any to start).
Anyone know why I can't raise the VCore when the CPU is being overclocked?
One thing, the VRM heatsink gets really hot. So I got an old 90mm fan and it cooled right down - didn't make any difference, though.
Spec: Asus M5A97 EVO R2.0 / AMD FX-8320 / 2x4GB 1867 Patriot Red / MSI 2GB 7850 / BeQuiet Pure Quiet L8 500W
