11 May 2013 at 17:46 #1 johnny sublime johnny sublime Associate Joined 5 Jul 2009 Posts 844 Location DONcaster hi guys ive recently swapped rooms with my brother and now i cant get a connection to my home hub is there anything i can do apart from move the hub
11 May 2013 at 18:04 #2 ots3go ots3go Associate Joined 15 Jan 2005 Posts 2,464 Location Leiden - NL Nope, if the broadcasts from the AP aren't reaching you, you'll either have to move the hub or repeat the signal.
11 May 2013 at 18:48 #3 johnny sublime johnny sublime Associate OP Joined 5 Jul 2009 Posts 844 Location DONcaster ok but i still dont get how one wall can stop the signal when i had two brick walls in the wall in my old room
11 May 2013 at 20:12 #4 Frank_Rizzo Frank_Rizzo Associate Joined 18 Mar 2003 Posts 1,138 Hot water tank, radiators, wiring can all affect the path of the signal. You may not need to move the hub that much. Try a few feet horizontally. Raise it higher.
12 May 2013 at 12:04 #5 garnhamr garnhamr Associate Joined 3 Sep 2010 Posts 132 would power link work here?
