Hi all,
Not sure if anyone here will be able to help but worth a try!
Over the weekend my phone died in my hands, it was on charge (low battery), turned off and wouldn't turn on again. It just displays the Samsung Galaxy Note logo and never gets passed that.
I tried to get into recovery CWM is installed) and I get MMC: mmc_read fail and Moviand Checksum Confirmation Fail.
I've tried to upload a PIT as Odin reports that there is no PIT partition - I'm using a few .pits I've found on the web and using the ROM from SamMobile - I believe this is the correct one. My sim is EE but the phone is unlocked so I picked the United Kingdom one. N9005XXUGNG1_N9005OXAGNJ3_N9005XXUGNG1_HOME.tar
However when I add the PIT to Odin and the tar to "PDA" in Odin I get "There is no PIT partition":
and on the screen itself in Download Mode gives these errors:
MMC: mmc_read fail
ODIN: flash read failure
SECURE CHECK FAIL: PIT
Could the hardware have failed... I'm not even that bothered about the phone itself, I just really want to try and get the data off it - but don't think there is a way to do this without booting into a ROM or at least recovery to use ADB.
Any help would be appreciated!
MMC: mmc_read fail
