15fps, really?
Yeah. Max, on Go Pro Hero 3+
Kind of defeats the point shooting in 4k when you can see the frame stutter.
Yeah I hear you. On reflection I would probably have not used that again.
Would probably drop down and use higher fps on another resolution.
25fps should be the bare minimum you aim for - drop the resolution before you drop the framerate.
1080p/30 for general stuff, or 1080p/60 (if it'll do it, else 720p/60) for high speed action![]()
Cheers for the feedback
As it offers 15ps for 4K where would that be used?
I had a bag of chips on that pier a few years ago running at 60fps.![]()
bit windy out there, id have been tucked up inside playing the fruit machines![]()
