Brisbane temps
10 Mar 2006
Hi
I've just got hold of an Brisbane 3600 x2 and an AC Freezer pro, but the temps that are being reported in coretemp/everest etc are different to what's being reported in the bios. Speeds are still at stock at present.
With the AC64 at 2krm it shows 38-40c in the bios and around 10-14c on each core in coretemp etc.
With the AC64 at 1krpm I get 40-44 in the bios and around 20c per core in coretemp.
Which one of these should I believe? The coretemp scores look surprisingly low, and the bios scores look too high considering I haven't overclocked at all. Any ideas?
It's a known sensor bug with the Brisbanes. There isn't all that much you can do except wait for future updates of the Coretemp program (assuming you're using 0.95 now) and future BIOS updates to recalibrate socket temperature.
In all honesty, neither sound correct. Probably your best bet is just to concentrate on the temperature difference between Idle and Load rather than the exact readings you are getting.
Mul
Yeah am using v0.95 now. There doesn't seem to be more than a 1-2 c difference between idle and load to be honest. I'm not massively concerned about the issue, because I have faith in AMD chips running pretty cool in general, and especially with the 65nm process, but I'm not too keen on having a crack at clocking it until I can get an accurate reading of the heat it's generating.
Ta for your help
