- 14 Jan 2007
When I built my PC and went to install windows on it. I can format the drive ok, via the windows boot-cd. The drive formats OK, and the set-up copies the files over. After this the set-up reboots.
When attempting to boot from the CD upon reboot, all i get is a blank screen. If I attempt to boot from the HDD it get an error. "Disk Read Error. Press Alt+crtl+del to restart'.
IIRC it's supposed to boot from the CD and continue the installation. However all i get is a blank Screen.
In order to get windows installer to run again i have to use a bootable disk manager to Zero entry to drive (setting it back to partitioned space). Then I can format the drive again, and the same problem will happen.
I can use a bootable Linux CD and access the drive and read some of the set-up files that the windows installer has put on there. Is the drive the cause of these problems, or is there some kind of problem with the grahpics for the blank screen. (I'm using on-board gfx)
Thanks for any help.
