- 28 Mar 2005
- Newbury
Hi all, I'm after some advice about the best way to get my iPhone repaired or replaced.
It's a 16gb 3g model if that makes any difference.
The problem is that silent switch on the phone appears to be playing up, if it's set to silent, a tiny amount of pressure in the top left of the phone cause it to flick rapidly between silent and loud. This is particularly annoying when it happens in my pocket.
How would I go about getting it replaced in the quickest way possible?
I can get to an apple store quite quickly, but I don't have the warranty details or box with me up at uni, and it's not easy to get hold of them. Will the store even talk to me without this?
If I'm unlikely to get any results through the store, what are my other options? The phone is only a few (3 or 4 I think) months old, so should be covered by warranty.
In advance thanks for your time.
